Power vent heater
I have a power vent water heater which I think made a strange sound today for about two seconds.
I was thinking it could be the draft inducer's motor / fan assembly. I put my hand on the motor
while it was running and it seemed pretty hot.
So I'm wondering if that's normal ?
  • ChrisJ
    ChrisJ Member Posts: 17,485
    Id prefer to use numbers rather than "feels hot" because we have no way of knowing what that means.
    Do you have an IR thermometer?
  • hunter29
    hunter29 Member Posts: 168
    edited December 2024
    Good point, no I don't but, I have to remove my hand after twenty seconds or it will start to burn.
    So maybe 135* ?
    I have a temperature strip sticky that came with my mixing valve, I'll put that on it and see.
  • hunter29
    Fwiw
  • hunter29
  • hunter29
    edited January 2025
    Short of letting it run another half hour it looks like it topped off at 125* surface temperature.
    And the cooling fan is blowing air.
  • hunter29
    Just a bump, I would say this is normal, anyone disagree ?
    HVACNUT Member Posts: 7,507
    Whats the room temperature?
    The motor is rated for 2.8 amps. Actual is…?
    hot_rod Member Posts: 27,707
    it look pretty dirty in the cooling slots, blast it out with some compressed air. Can hurt.
  • hunter29
    edited January 2025
    Good ideas guy's, thanks..
    It wasn't as dirty as it looked but I cleaned it anyway.
    Running at that temperature 120/125* it was drawing 2.26 amps… at 64* room temp..
    pecmsg Member Posts: 7,194
    Drawing 2.26 and rated for 2.8 Not bad. ASSUMING the voltage is 115.
  • hunter29
    it is…
