Need help with wall heater
hello my wall heater just started acting up. I jumped the wires at the thermostat and no luck replaced the thermopile and still didn’t work. I jumped the terminals at the regulator and she fires up. I’ve checked all the electrical connections and everything looks good. What am I missing ?
A limit control
also when I relight pilot light it will fire up for a split second then shut off
Thanks in advance for any input0 -
Follow the blue wires thru the heater. they will go to a limit control or maybe a series of limit controls. one of the limit controls may be a manual reset control. It may look like this
Thx Ed. That reset was in the up position I pushed it down and the stove still doesn’t operate. Attached is photo of my pilot. Looks as strong as it normally is o I don’t believe it a clogged pilot.
disregard thank you Ed that was the problem! Very much appreciated my cold family thanks you!
where is the filter at?
Does this furnace have a fan to circulate the warm air, or does it operate by gravity?
If it's gravity, there is no filter. If there is a fan, the filter will be between the return air intake and the fan.
If you post a photo with the cover off, we can probably help you find it.—
Bburd0
- 125 Chimneys & Flues
