Electric Radiator Tripping
Hi, i have 1 electric radiator in my flat with 3 storage heaters. The Radiator keeps tripping out along with the water tank as they’re on the same switch..
Anyone have any guesses as to what would cause it to keep tripping? We’ve lived here for 4 years and this is the first winter it has done this. Some days it will be fine for me to heat the room, other days it will trip every 5/10 minutes
i have attached a few images
Is it a circuit breaker or safety in the heater which is tripping, or is it the whole circuit including the water heater? And if it is the whole circuit, is the water heater on when it trips?
Is it tripping on overcurrent? Or something else (like a ground or arc fault)? Can you tell?
Hi, I'll add that at least in the US, circuit breakers are only good for being tripped about five times. After that they trip at lower and lower amp draws. That could be contributing to the problem. 🤔
Yours, Larry
- 125 Chimneys & Flues
