Learning more about steam Boiler and getting a little worried
Hi Friends,
I want to thank everyone for helping me with my pressuretrol/pigtail issue from a previous thread.
Now that I have a better understanding of steam from dealing with my current boiler and previously at my parents, I wanted to make sure I get it to be efficient and operate well.
I've attached some photos from my boiler in the follow up comment below.
I had some questions that I was hoping you guys can answer.
- My current boiler seems to have the automatic water feeder on the cold water line, is that okay? This boiler has been working for previous owners since 2000.
- Is there a specific color that the flames should be on the burner? How easy is it to clean the burners?
- Is it possible for me to get the boiler tested for the different gases without having to hire a technician company?
- How do I test a low water cutoff/probe? I see a manual button and a test symbol.
- How safe are these steam boilers? I was told they have multiple safety in place to ensure the boiler is cutoff in case of any issues.
I will ask more questions as they come to me.
Thanks again for all the help!
please see more photos of the boiler.
let me know what I could potentially do.0 -
- Yes
- Blue. They are easy to clean.
- I'd just hire an hvac tech with a combustion analyzer and ask them to analyze it. Actually, I'd buy a Testo 320, and I did, but you should hire someone
- Lower the water level while the boiler is running and see if the LWCO kills the boiler.
- They are safe if the safeties are operational. Even if the electric safeties are not working, there is a pressure safety relief that should let pressure escape at 15 psi
I don't think the flames are blue on mine, they seem yellow-ish.
It's probably from dust. I see a lot of dust in your photos. But the flames should be mostly blue. A competent boiler tech should be able to tell you how the combustion is looking.
Might just be dust. Boiler off, those burner tubes can be removed and vacuumed. Sending a boiler brush through your heat exchanger wouldn't hurt either.
Get a tech to do a combustion test after everything is clean.
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
