Adding water to boiler system
amyjo28
amyjo28 Member Posts: 2
Hello! I'm a newer homeowner and have never had a gas broiler for heat that feeds to the radiators in our home. Our boiler recently stopped keeping up with the thermostat and I noticed the temperature on the boiler not getting as hot and the PSI was low. The temp won't currently go above 75 or so and PSI is at about a 7. I had the HVAC technician come out and take a look and he said I'd need to add water and possibly bleed the radiators. He said he could not do this for me as he's not a plumber but could do it myself or call a plumber. My question is, is adding water to this boiler as simple as turning both of these valves on until the PSI gets to 10-15 as he suggested and then closing them once it gets there? Any particular order in opening both valves? I assume I should have the system off and cold as well before doing so? Thank you for any assistance!
    Jamie Hall Member Posts: 27,580
    Just exactly that simple. Doesn't even have to really be cold when you do it, either. Keep an eye on the pressure gauge, though — it may increase rather quickly. And then make sure the valves are closed.
    amyjo28
  • amyjo28
    Thank you for your help Jaime! I think I'm feeling brave enough to give it a whirl, lol.
    delcrossv
