Can I set this pressuretrol lower
here’s a picture of my cut in and cut out pressuretrols (I think). My boiler is cutting out at just about 1.5 psi (see 3rd picture). Can I adjust these lower or do I need the ones that measure in ounces? Vaporstats I believe they are called.
I have an oversized boiler and don’t mind a cycle. Right now I can keep the house constant on 1 cycle but the pressure builds.
That is not a vapor stat but if the system heats ok with no banging and the air vents work you can leave it as is if it stays at 1 1/2 psi or less.
Not likely you can adjust that one any lower. For that you need to keep that old control and add a vapor stat.
If you add a vaporstat uses all brass fittings and pigtails (no black fittings they plug up). It is better if the vapor stat is connected to the boiler in a different location than the old control if you have a spare tapping. Safer that way.
You should remove that old control and make sure the fittings and pigtail are clear and clean every year or two.
1 -
No, that's as low as you can go with that style pressuretrol. However, unless this is a system which was designed for very low pressure (vapour) steam, and has been kept that way, there's no reason to go any lower. What you have is fine.
thanks both!
