Temp drops to 55 at night
lab
lab Member Posts: 3
although my forced air gas furnace keeps the temp I set, 68°, 24/7, it drops to 55° at night. The furnace feels warm, so I thought maybe the fan wasn’t working. I set the thermostat to the fan staying on and it worked, but the temp didn’t go up.
Can anyone help?
    hot_rod Member Posts: 27,838
    filters clean? Did it work years past?
    Keep the thermostat in the heat mode.
  • lab
    lab Member Posts: 3
    yes it worked in the past and until a couple nights ago. Blower fuse was replaced about 6 months ago; Other than that, no issues. Thermostat is in heat mode -
    Jamie Hall Member Posts: 27,580
    Do you have a setback on the thermostat?
  • worldclasshvac
    worldclasshvac Member Posts: 40
    Ita likely tripping a limit and shutting down prematurely. Very common issue and the fix depends on what furnace is there. Post the model #. Could also be weak inducer causing pressure switch to flutter
  • lab
    lab Member Posts: 3
    thank you all. I had a friend check it because it quit completely, and it’s a relay. Won’t be here til Monday, but it’s a $4.50 part.
    PC7060
