IBC SL 28 160 : Excessive Condensation Draining?
R350NYC
R350NYC Member Posts: 2
Hi,
I have an IBC SL 28 160 boiler and noticed that there is a decent amount of condensate dripping from the drain pipe. Below is a video. Is this normal? Do I need to service it?
Thanks!
    pecmsg Member Posts: 7,281
    it’s cold out there’s going to be a lot.
    EBEBRATT-Ed Member Posts: 20,476
    It is either normal or the heat exchanger is leaking. If the boiler is holding pressure and not adding MU water then don't worry about it.
