Space heater vs. Turning up the heat?
One zone oil/steam. I set house to be 60 when at work and overnight. I am often home alone. Sitting in living room on weekdays home from 5pm-bedtime. I have been using a small 750W space heater to heat my legs in the evening. Say house is at 61-63, naturally. I'd need to run boiler for 20-30 mins to raise temp to 66-67, which would then slowly decay until 10pm. What's the correct thing to do? Space heater vs. Turning up the heat? What is the general consensus on this?
  • I fed that same prompt to GPT, if you're curious what it said.
    Using a space heater versus turning up your central heating depends on several factors, including energy costs, the size of the space you need to heat, and your personal comfort preferences. Here’s a breakdown to help decide what’s best for your scenario:
    Cost Comparison
    1. Space Heater:
      • Your 750W heater costs $0.22/hour (at $0.29/kWh total energy cost).
      • For 5 hours of use per evening:
        0.22 × 5 = $1.10/day or about $33/month (based on weekdays only).
      • Space heaters are ideal for heating a small, localized area when you're stationary (e.g., sitting at a desk or watching TV).
    2. Turning Up the Heat (Boiler for 20-30 Minutes):
      • Oil consumption: A boiler typically burns 0.8-1.7 gallons/hour for a home like yours. Assuming 1 gallon/hour:
        • 0.5 hours × $4/gallon (approximate oil cost) = $2.00 per use.
        • For 5 evenings per week: $10/week or $40/month.
      • Central heating warms the whole house, which may feel more comfortable but is less targeted.
    Efficiency and Comfort
    • Space Heater:
      • More efficient for localized warmth.
      • Allows you to keep the house cooler overall, saving energy.
      • Works well in small spaces or for single-person use.
    • Central Heating:
      • Provides even heating throughout the house.
      • Reduces risks like frozen pipes if outside temperatures are extremely low.
      • May feel more comfortable if you frequently move between rooms.
    When to Choose Each
    • Space Heater: Best when you’re stationary and only need to heat a small area, such as when sitting on the couch or working at a desk. It’s economical and avoids unnecessary heating of unoccupied spaces.
    • Central Heating: Makes sense if:
      • You feel uncomfortable in other parts of the house.
      • The space heater can’t adequately warm your surroundings.
      • You’re hosting guests or moving between rooms frequently.
    Other Considerations
    1. Wear Layers: Using blankets, warm clothing, or heated pads can complement a space heater, reducing the need for central heat.
    2. Steam System Efficiency: Your one-zone oil/steam system takes time to distribute heat. Upgrading vents or adding more efficient controls (e.g., programmable thermostats) could optimize its use when needed.
    3. Safety: Always prioritize safety with space heaters—ensure tip-over protection and avoid leaving them unattended.
    General Consensus
    Most energy experts and homeowners agree that space heaters are cost-effective for targeted heating, especially in scenarios like yours. However, central heating is better for whole-home comfort or in situations where a consistent, evenly heated environment is necessary. Balancing both approaches based on your habits (e.g., space heater during solitary evenings, central heat for broader use) can provide the best compromise.
    ethicalpaul Posts: 9,097
    I’m sure it’s cheaper to run the space heater than to heat the whole house, so you do you!
  • PC7060
    PC7060 Posts: 1,982
    haha, funny to see ChatGpt quoted. for a while Ive been wondering if Coach is a AI agent posting a multitude of cases and problems to expand the ChatGpt overlord’s knowledge!
    ethicalpaulJUGHNE
