The orifice
How do u find the orifice on a natural gas 5 burner wall mount heater?
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,464
    Picture? Usually a small Brass barrel. What are trying to do? Mad Dog
    EdTheHeaterMan Member Posts: 11,752
    edited November 2024
    "a natural gas 5 burner wall mount heater" is not enough information to give you an answer. I would answer where the gas comes into the burner(s). or Somewhere between the gas inlet and the flame
    That is like asking "on a foreign made car, where do you find the gas cap?" Answer: That would be at the end the gas tank fill tube
    delcrossv
  • Tim McElwain
    Tim McElwain Member Posts: 4,658
    As you follow the gas line to the unit and come to the heater and look inside were the flame typically appears you will find some tubes (burners), the orifices are located back at the manifold that holds those burners.
  • Lance
    Lance Member Posts: 330
    If you can find an orifice blank to fit, and know the orifice size, you can drill out the hole and put it in.
    Contact the manufacturer for the info.
