Fix for cut threads on my radiator bushing....
branimal
branimal Member Posts: 301
edited November 2024 in Strictly Steam
I was replacing the valve and cut the bushing threads slightly when cutting out the brass valve spud. I installed the new valve with Hercules Blue BLOCK sealant. When the heat came on it was leaking at the bushing.
Should I retry with more sealant and teflon tape? Or should I cut out the damaged bushing?
  • PC7060
    PC7060 Member Posts: 1,844
    Wrap the valve with a high quality teflon tape; as much as you feel comfortable with. Apply sealant over tape and install. Don’t be an afraid to tighten to German “gudentite” standard.
    Not sure how much time the Hercules need to set (if any). I’ve used rector seal 5 in similar situation and prefer to let cure before applying pressure.
    branimalMad Dog_2
  • Grallert
    Grallert Member Posts: 1,148
    Try @PC7060 's suggestion but be careful not to break the tabs inside the spud. If that fails you can try JB Weld on the inside of the bushing or just pie cut the bushing and snap it out and start over with a new bushing.
    branimalPC7060
  • AdmiralYoda
    AdmiralYoda Member Posts: 798
    A picture would help! But perhaps some JB Weld to fill in the cut threads. Clean the heck out of the threads and shmear some JB Weld in there, let it cure and tap/clean up the threads?
    Then go a little overboard with the sealant and tape.
    branimal
    ethicalpaul Member Posts: 8,933
    My slightly cut threads always held tight with blue monster tape and no dope
    branimal
  • Robertw
    Robertw Member Posts: 88
    Old school lamp wick and megalock was my go to in this situation
    Robert W.
    Energy Kinetics
    PC7060branimal
    EBEBRATT-Ed Member Posts: 20,481
    Depends on the size of the cut.
    All the above solutions may work. Expando dope is another option you mix it with water and apply it. Most of the time the standard tricks work. If not cut the bushing out carefully.
    branimal
  • delcrossv
    delcrossv Member Posts: 2,204
    Linen thread/ lampwick then teflon tape.
    BobCbranimalRobertw
  • branimal
    Wrapped it with tape and sealant and torqued it on. Then let it sit overnight.
    Just tested it and it's not leaking.
    Thanks guys.
    delcrossvPC7060
