Temperature setting for aquastat on steam boiler
hi
I have Weil McClain eg50 that has a hot water coil in it. I don’t use the coil for hot water on anymore, what temperature should I keep the aquastat at?
    Jamie Hall Member Posts: 27,582
    Off. No need to maintain the boiler at any particular temperature — let the house thermostat run it in the usual way.
    bbillcee
    EBEBRATT-Ed Member Posts: 20,481
    Disconnect the two wires from the aquastat and tape them up or wire nut them separately.
    bbillcee
