Weil McLain Lgb 6-23 battery backup
Does anyone know approximately what the unit draws in watts - it is 120v. I’m not near the unit and did not find it in a manual . I was thinking of getting a 1000-2000WH battery generator like Echo flow or Jackery . Any suggestions or warnings?
I don't have the manual either — but if it's more or less typical and on a 15 amp fused circuit, I'd make a quick guess — probably close enough — that it draws somewhere between 500 and 1000 watts running, and around 1.5 kW starting (briefly).
Two things to consider on the battery "generator". First, check the surge output capability. It must be at least 1.5 kW. The second, though, is this: either unit you mention, if they have the surge capacity, should be able to run the boiler. For a while. Remember that unlike a fuel fired real generator, these things are really batteries with an inverter — and when the battery goes flat, that's it. You can't just pour in more gas and off you go. With the larger unit you mention, and the smaller draw I estimate, you'd have no more than 4 hours of operation — and going the other way, you're down to one hour (powering nothing else). Is that long enough to cover your needs?
Edit: I notice that the Jackery web site cheerfully notes that when the battery goes down you can recharge it from solar (with the sun out and a good big array) or a USB port (but what is powering that?) or plug it in (to what????)
I’ll put an amp meter on it tomorrow, but from what I see I don’t think more than 50-150 watts. There are no motors. Just a thermostat, two gas valves and two electronic units that run cool to the touch. And at idle probably no more than 10 watts. But I’m guessing. A small furnace with a blower for a home uses about 450 watts with an AC blower. This boiler has none of this .
1 -
atmospheric steam? You may be right. Hot water? Don't forget the circulating pumps…
yes steam, no pump no blower. I will test it with an amp meter soon.
Will you have a generator available to run the battery charger if the power goes out for several days?
Yes , I have a nice small Yamaha inverter generator that would charge batteries. I’m getting a real small Tri fuel Honda Eu 2000i Inverter Generator, NG , Propane, Gas. It is a conversion added to the generator.
I imagine you could run the battery powered one at night, if you objected to the noise of the gasoline or LP fueled ones. That would work…
One thing about it, though — it would take the 2,000 watt gas one running flat out for an hour to charge the 2,000 Watt-hour battery. Couldn't run anything else during that time.
I must admit that yeah, it all will work… but it surely is the hard way to do it, unless you live in a jurisdiction which has prohibited or severely limits fuel fired generators…
no battery of 2000w can take 2000w in an hour to charge it, it will kill the battery. It might take 12 hours at least. I could buy car batteries and an inverter, I don’t know yet. Today I should know power consumption, I think it’s low enough to get 2-4 days running off batteries . My electric usage doesn’t go up much in winter, I don’t think power consumption is much. This might never get used, it’s in Chicago where power is good. So I will do it inexpensively
I know this thread is a bit old, but I’ve seen similar LGB models pull very little on 120 volts—usually just enough for the gas valve and controls, often under 100 watts total. The big draw is the damper motor if one is installed. If anyone has an LGB 6-23 on hand, could you share the actual amperage from the data plate? That would pin this down for battery backup planning.
You can ballpark the draw at around a couple hundred watts for the controls and blower, but the safest move is to size the battery backup for the inrush load too, since that can briefly spike. I’ve used lr1130 battery equivalent products for small control gadgets during setup, and it reminded me how even tiny loads add up, so giving yourself a buffer on capacity makes life easier.
Keep in mind that the above is all for an atmospheric gas fired steam boiler. It doesn't apply to a hot water system (except gravity) nor does it apply to a power burner for gas, nor for an oil fired boiler, nor for any system which depends on power inlet or exhaust vent fans.
Never mind forced air or heat pumps.
