Test gas valve
hankwylerjr
hankwylerjr Member Posts: 158
what’s the best way to check a gas valve on a boiler or furnace etc to see if it’s bad or good? I like the multi meter
    Jamie Hall Member Posts: 27,400
    While a multimeter might at least tell you in the windings are open, it won't tell you whether or not the valve actually works.
    hankwylerjr
    hot_rod Member Posts: 27,510
    turn the heat up, see if the unit fires🤔
    I don’t know of any way to do a stress test to determine the life left, if that is what you have in mind.
    If it doesn’t fire at all, then you need to use a meter and understand the wiring diagrams included inside most manuals, or the jacket itself.
  • Kenneth111
    Kenneth111 Member Posts: 1
    edited September 2024
    Set it to measure resistance (ohms) and check the terminals. If there's continuity, the valve is likely good; if not, it could be defective. For more help I recommend to contact heating repair company in Sacramento https://alphamechanicals.com/heating-repair/ for additional information and professional point of view.
