Residential boiler work
I am inquiring about anyone who does residential boiler work in the Seattle area. It is an oil fired Burnham boiler two zone baseboard system. I am a boiler contractor in Santa Barbara , Ca . It is for some friends of mine who live up in the Seattle area. By Holler Lake North Seattle
    EdTheHeaterMan Member Posts: 12,190
    edited August 2024
    I would suggest that you use the Find a Contractor link above, however it appears that there are no Washington State listings. The next best thing is to contact a fuel oil dealer close to your friend (or even the fuel dealer that delivers their oil) to see if they have a service department, or recommend a good oil burner tech in the area.
    I happen to be that recommended tech in southern NJ when I was in business. Seems that my retirement left a huge void in that area. But you can't do repair work from a wheelchair.
    Greening
    hot_rod Member Posts: 27,470
    Paul Pollets on this list in in that area
    GGrossmattmia2kcopp
    ethicalpaul Member Posts: 8,807
    I wonder why he's not on the contractor list…it's only a dollar a day
    Alan (California Radiant) Forbes Member Posts: 4,724
    edited September 2024
    @Paul Pollets is retired. But he should have some referrals. pgpollets@msn.com
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    I refer oil systems to Jeff Nadeau at Custom Radiant. 206-465-0998. He has extensive oil background and used to repair jet engines in the Air Force.
    PC7060
  • HomerJSmith
    HomerJSmith Member Posts: 2,779
    I use to go fishing in Haller lake. There once was a big amusement center on Bitter lake, I fished both lakes. Roller Coaster and all. A few blocks away there was a Speedway racing track for derby race cars. Old memories.
