Electrical hot water, 1930
I doubt this is a "first" but it seems to be all the modern features in one product, in 1930.
Note that "series with a furnace or range" was still a thing.
They had electricity in that part of PA. in 1930?
What "part of PA."?
wonder if it had a temperature and pressure relief valve
What is the dingus on the top of the "oil vacuum tube"? Kinda T&P valve shape. Seems to blow-off into insulation, but maybe it did, or maybe the blow-pipe has been omitted, or maybe the artist didn't have a clear picture to work from. And as you say: it was decades away from being universal.
As for repeated use of "vacuum tube"… it's 1930. Thermionic valves were in limited use 1910, commercial use 1920, but 1929 is about when "EVERY" home had radio (vacuum) tubes, or wished they did. Maybe on a new product that year, when you type "tube", your fingers throw on a "vacuum" automatically. But the concept only makes sense if the tube is full of oil or similar heat transfer fluid.
1 -
- 120 Geothermal
- 169 Indoor-Air Quality
