Head of Schools house
We acquired this house a few years ago. 3000sf colonial built around 1980? vinyl siding half finished basement. The finished side of the basement has carpet (new) drywall newly painted and a dehumidifier runs all the time. The complaint is allergic reaction to…? not sure. We have an outfit coming to have a look. I did check the moisture level in the finished side of the cellar at the bottom of the drywall and got between 10% and 15% seems to me that should be lower. The wall in the unfinished side is below 5%. Seems to me air movement is needed at the very least. There is no visible mold but there is some pealing paint at the base board molding in spots.
I should say the building has ne cooling other that a window shaker on the second floor. There is space in the attic for an AC unit I think. I'm sort of answering my own question as I sort out my thoughts. Thanks for listening :)
I think you already know where this is going… the combination of a below grade basement, carpet (on the slab?) and drywall (any furring under it?) just is asking for trouble…
I'm afraid there's instant fix. Yes below grade carpet on slab, 3 1/2" dead air between foundation and and drywall glass insulation, more where the waste leaves. It seems like the drywall is absorbing the bulk of the humidity. The answer is easy just not pleasent.
1
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
