Do seals ever seize?
jumper
jumper Member Posts: 2,575
I've never seen one but I've experienced stuck ball valves.
  • ChrisJ
    ChrisJ Member Posts: 17,481
    What kind of seals specifically?
    I've heard of rubber seals getting stuck on motor shafts after sitting and getting torn when it starts.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,642
    Absolutely...every mechanical joint has a life span....If it's not regularly exercised, greased & maintained...expect premature failure Mad Dog 🐕
  • Intplm.
    Intplm. Member Posts: 3,069
    Yes.
  • jumper
    I've got a stuck ball valve, open, in a place where I dread replacing it. Should I try hammering on the handle? My inclination is to remove handle so that nobody else will try.
    mattmia2Mad Dog_2
    hot_rod Member Posts: 27,703
    They tend to dry out and get hard and brittle. Leave o rings around your shop exposed for several years and they are useless.
    Water quality and chemicals used in public water can damage rubbers and composites.
  • Intplm.
    Sounds like the Delrin seal around the internal stainless steal ball has indeed seized.No hammering will change things. It needs to be replaced.
    Mad Dog_2
    mattmia2 Member Posts: 17,206
    If it is scale that has formed on the ball holding it in place and that is likely what happened, you might be able to put a citric acid solution in that part of the piping and let it soak a while and dissolve enough deposits to free the ball. Of course the chances that it won't hold because there is still some scale on the ball are high.
  • jumper
    Thank you Intlm & Mattmia. Guess I did not exercise that valve often enough? Each leap year.
  • Mad Dog_2
    You could try to take off the handle and WD 40 the gland. It MIGHT loosen up a bit where you start to get it moving. If not...OUT. Mad Dog 🐕
