Odd nipple....
1 1/2" "Hubbed" nipple...Anyone ever use one of these? Proper name? Mad Dog π
whatβs the application?
Is it a reducing nipple also?
Swage nipple male X female is what I would call. I'm not sure there is such a thing?
Living the hydronic dream0 -
It looks like it was welded in the field and not an off-the-shelf fitting. It was probably made late on a Friday afternoon or on a weekend call.
What's the pipe carrying?
@Mad Dog_2 - ever curious! Now the rest of us are going to have to wonder whatβs running through that pipe!
π0 -
You have to go back and check. You're leaving us all hanging. LOLπ
I will take a guess: Gas
1 -
What is a hubbed nipple? Are you looking at a male x female nipple or a nipple with the hex in the middle?
It's odd...that's why I stopped & took a picture. It is 1 1/2" Galvanized malleable fitting. It could be some proprietary gas utility nipple.....Mad Dog π
1 -
The Lozone Nipple Bushing is what we call an 'extension coupling." This has a female threaded hub attached to a 8" nipple. All one piece. Mad Dog π
In the old days the gas in the street could be anything. CI & wood pipe included.
how exactly do you pour that? the runner isn't going to make the lead run uphill.
A upside down, vertical lead joint.
It need a really broken in, old joint runner. Clip it really tight. Build a funnel out Flue pipe or whatever., and stuff any crevices with oakum. Make sure the top of the funnel is higher than the top of the hub and pour it like any other lead joint.
The molten lead, like water, will seek it's own level. Mad Dog π
2 -
Yep, not fun.
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
