Can I shut my Ecobee thermostat off?
Will I still have hot water? I don't need heat, nor AC at this point. My system is old, and costs a lot! to run. 3-400+ a month.
I'd just like to shut it off.
EDIT: YES Turn off the thermostat
That will depend on the system. Your AC is definitely not a boiler system, AC needs to use duct work and a fan 98% of the time.
Your heater is a different story. You may have a furnace (hot air)that uses the AC ductwork, or a boiler (hot water or steam), that will usually use radiators, or maybe radiant floor heat or in some cases a hot water coil in the ductwork.
One other popular heating system is a heat pump that uses the outdoor AC compressor in reverse, to put warm air in the ductwork.
Can you describe your heating system?
For the most part, the Heat Pump, and Furnace systems have no attachment to your Domestic Hot Water (DHW) On the other hand, a steam or hot water radiator system may also operate with a tankless coil inside the boiler. You can not shut off the boiler system if you have that type of hot water heater.
You can shut off the thermostat on just about any system, and still get hot water, because that room thermostat only controls the room heating side of the system. The hot water side of any system is controlled by a thermostat in the water heater, not the one on the wall.
Thank you both! I don't know enough about what type of geo thermal system I have-other than I had it checked and was told I need a new heat pump as mine is outdated.
I'm shutting 'er down for the summer! I don't care about AC. I live in Minnesota, and summers are short with only a shorter hot season.
Again, thank you. Very, very much.
The majority of Geothermal systems are heat pump design. That means that you probably have a separate hot water tank that operates on electric resistance elements. Key word being Probably. There are heat pump water heaters and also indirect water heater tanks that have hot coils inside them that operate off of any number of heat sources. You may have has some crazy unconventional assembly of parts that use the geothermal to heat the water.
BUT Probably not.
- 135 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Job Opportunities
