Fitting Thread sizes
kennethruiz
kennethruiz Member Posts: 4
I have an Uponor EP heating manifold. The loop male thread connections are listed as R20.
I want to make sure, before ordering, that Caleffi Fitting 5/16" PEX Loop Fitting for Manifolds is compatible.
The supplier was unable to confirm. These are half the price of Uponor's and I need 10.
Thanks in advance for any help.
    Jamie Hall Member Posts: 27,677
    It is my understanding that R thread is the same as — or very similar to — British Parallel Pipe Thread — BPPT. It is NOT interchangeable with NPT. Not sure what thread the Caleffi manifold uses ( @hot_rod ?)
    kennethruiz
  • kennethruiz
    Thank you, from the research and information I could find, I believe you are correct.
    The only information on the Caleffi thread is : 3/4". no other information is provided.
    Thanks again.
    hot_rod Member Posts: 28,065
    the R20 thread is a standard, straight thread, but the shape of the tailpiece and o ring can vary from brand to brand, where it seals into the manifold
    The Caleffi has both a taper and o ring, so it is fairly universal
    Also, the part that goes into the pex has a slight taper and an o ring for pex that may have a large id
