removing an old boiler drain valve
i would like to remove and replace 2 boiler drain valves that are installed in an oatey washing machine outlet box. They are 27 years old and dont shut off too well. they are connected to copper. can i use put a wrench on them and unthread them . i am a little worried about damaging the pipe behind the wall
Yeah I would be too , Two wrenches are needed to prevent twisting the piping . Looks like the locking nut is missing on the supply nipple . See if you can pull up to grab the nipple . If not it will be safer to replace the box …
- 120 Geothermal
- 394 Solar
