Build Up in Condensate Neutralizer
bassman951
Member Posts: 2
in Gas Heating
I'm a homeowner who installed a condensate neutralizer on my mod-con boiler a few years back.
During the heating season, this gunk (see picture) builds up in the neutralizing media that eventually clogs it, leading to condensate bypassing the media. I then need to disassemble the neutralizer and wash/rinse everything as best I can, including the condensate trap on the boiler and piping leading to the neutralizer.
I can get most of the gunk off the media, but it is harder to clean it off the trap, piping, and neutralizer body.
It is annoying to have to do this multiple times per heating season, so I was wondering if anyone had advice on how best to clean everything and maybe prevent it from coming back...or at least limit the number of times I need to clean it.
That neutralizer is pretty small; you can get larger ones that have a greater capacity. But I'm surprised that the system needs cleaning so often and it could be an indication of something going on in the boiler's heat exchanger.
What is the make and model of your boiler? Natural gas or propane?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab2 -
It's a natural gas boiler that is probably oversized for my house, so maybe it's not producing enough condensate flow to prevent the build up?
I rinse the media to try to get off as much of the build up as possible and then put it back in service since most of the pellets seem to be full size. My process is:
1. put media in small bucket
2. fill bucket with tap water
3. agitate
4. pour out dirty water
5. Repeat steps 2-4 until water looks relatively clear.0 -
AFAICT, those pellets never dissolve. I had a bad time this winter with gunk build-up and I think I'm buying new pellets this summer. They come in pounds and diameters:bassman951 said:....most of the pellets seem to be full size. ....
https://www.amazon.com/Rinnai-809000114-Condensate-Neutralizer-Refill/dp/B00K86A4SY
And yeah, I think your model is small.
