Even Slow Drips Add Up Over Time
EricPeterson
Member Posts: 307
At the start of the heating season I installed
However in the installation process, the near-boiler piping did have some very minor leaks - an occasional drip, and some moisture visible at some of the fittings. I was not overly concerned as I monitor the status of the boiler on a regular basis as it is right next to my basement workshop. This is something I planned to address after the heating season.
Over time I noticed that the system pressure would slowly drop, and also that that I now had the opposite of a water-logged compression tank.
That is to say, the water level in the compression tank was ever so slowly going down. I could tell by lifting one end of it slightly to gauge how full of water it was.
Also it was taking longer to bring the pressure back up which I was doing with a bike pump and a Schrader valve fitting on the tank. It was taking longer (more pump strokes) because the volume of air in the tank has increased.
I confirmed this today by using the ATF-12 to bring the water back up to the proper level.
So slow drip by slow drip I lost quite a few gallons of water over the past six months.
This seems to me to be the proper explanation for what I have observed.
Eric
- Airtrol ATF-12
- Caleffi 280 Mixing Valve
Eric
One normal sized drip every 10 seconds or so is a gallon per day... they do add up!Br. Jamie, osb
Ain't it the truth.Jamie Hall said:One normal sized drip every 10 seconds or so is a gallon per day... they do add up!
Six months works out to 180 days, my tank is 24 gallons, and IIRC it should be 2/3 full of water which would be 16 gallons. A drip every 10 seconds would be 180 gallons so obviously that was not the case.
Supposing though 8 gallons were left, so I think that would work out to a drip every 40 minutes. That seems possible since a lot would evaporate when the pipes are warm.
I'll get this all fixed during the summer!
Eric0
- 128 Chimneys & Flues
