New type of 100% efficiency furnace?
Nhaggard07
Nhaggard07 Member Posts: 7
My buddy sent me this one today. The things some people do.. wow.
    HVACNUT Member Posts: 7,526
    It doesn't look like an electric furnace.
    MaxMercy
  • Nhaggard07
    No sir, it's not. I was commenting at the exhaust being ran straight into the plenum..
    delcrossv
    pecmsg Member Posts: 7,281
    All that corrosion says different!
  • delcrossv
    delcrossv Member Posts: 2,204
    Well, the person won't be complaining for long. 😬
  • pedmec
    pedmec Member Posts: 1,460
    is that a suicide install?
    Steamhead Member Posts: 18,705
    You can't fix stupid!
    Consulting
    delcrossv
    EBEBRATT-Ed Member Posts: 20,476
    There is a reason for permits, inspections and having a license.
    jimna01
    Yeah, I see... kind of. Let's see a shot from the side that shows it's BS.
  • delcrossv
    Steamhead
  • exqheat
    exqheat Member Posts: 223
    The logic is exquisite.
    I disagree with the assumptions.
    John Cockerill Exquisite Heat www.exqheat.com Precisions boiler control from indoor reset.
  • JUGHNE
    JUGHNE Member Posts: 11,603
    The few (lowboy) oil furnaces I have worked on would have the first 3-4' of exhaust in the RA plenum just above the blower.
    Perhaps this 6" goes thru the SA plenum and exits the other side.....might explain the condensation leaking out of the lower fittings.
    mattmia2MaxMercy
    mattmia2 Member Posts: 17,466
    i cam here to ask the same thing. is it like an old lowboy where where the vent ran out the back above the blower.
    also, the combustion efficiency isn't 100% so it isn't 100% efficient even if it vents in to the supply plenum.
  • JUGHNE
    This looks to be a plain jane 80% furnace, blower on the bottom, AC coil above burner.
    They may have thought by putting the exhaust pipe in the air stream they could milk more heat out of the furnace.
    Or decided to go through instead of around. The proximity of the vent and the filter in those lowboys seemed to be an issue.
  • MaxMercy
    MaxMercy Member Posts: 609
    edited March 2024
    Hopefully it's a one piece pipe inside the plenum at least - until it rots of course...
    It's an optical illusion. I don't see a clinch collar. I don't see any flange or masking or retort cement where they (supposedly) meet. I'm sure if the angle was 90° from what we're looking at, we'd see there's no penetration.
    Unfortunately we can't see where the water heater flue is going.
    Anyway, I call BS.
    PRR
