A False Water Line for Steam Heating Systems
HeatingHelp
Administrator Posts: 727
When 'modern' steam boilers replace their coal-fired antecedents, water levels in the system drop, often exposing purposely flooded wet returns to steam, with the result of destructive water hammer. One solution is to "trick" the old piping to hold water again, while allowing the boilers to operate at their new lower water level.
In Dan's book, it calls for a vent at the top of the false water line piping. I see you do not have one. Seems to still work.
It works like a charm. I walked in on a boiler that just blew steam right out of a condensate return pump. This was a new install by a local oil company. I called Dan and he sent me a drawing of what I needed. I had to make it from scratch. It involved a 3' piece of 8" steel pipe with 1/4" plate steel welded top and bottom. I put 3/4 thread o lets for 2 bucket traps and a drain. I put 2" thread o lets The traps were installed strategically to set the water line. I remember putting adjustable feet on it so I could raise and lower it if needed. Didn't need them. This goes back many years and I don't remember the details of all of it.. but I do know it worked perfectly.
There isn't a vent -- what there is is that steam line which, as Gordo said, equalizes the pressure at the top of the false waterline loop and the rest of the system. You do need to have that connection. You could also have a vent -- but I'm not sure what good it would do.Dave Stroman said:In Dan's book, it calls for a vent at the top of the false water line piping. I see you do not have one. Seems to still work.
- 128 Chimneys & Flues
