Brown water in boiler sight glass
HG1
HG1 Member Posts: 1
edited March 2024 in Gas Heating
The water in the sight glass was clear yesterday, and brown today. What should/can I do to address this?
Update: a new Spill Switch was installed on Monday (two days ago). And the water in the sight glass is dropping more then usual in calls for heat.
  • Intplm.
    Intplm. Member Posts: 3,081
    There is a process called skimming the boiler that helps.
    Was any work of any kind recently done on any part of your system?
    ethicalpaul Member Posts: 8,930
    Possibly nothing. Did something happen yesterday?
    You could drain the boiler and refill it with clean water, but the problem is that fresh water contains a lot of oxygen which will cause more brown water. You could drain the boiler and fill it with clean water that you then treat with an additive such as "8-way" to raise the PH level to 10 or 11 where the corrosion will be greatly reduced, but it can actually be difficult to find a place to add the additive unless you're handy.
    How is the boiler performing? Is the water level in the gauge glass dropping noticeably during a call for heat?
