New Boiler Installation
Next I have to have it inspected following which I will ask one of you fine folks look it over and do the combustion tuning.
Here are some photos. Ignore the wet spots on the floor.
Looks great but I have to hate on that hot water coil! I don't hate the CycleGard though!
See my sight glass boiler videos: https://bit.ly/3sZW1el1 -
Piping looks good. Did the burner come off another SGO-3? Also, could you have used a single oil line?
@ethicalpaul Thanks. Yeah, I may someday replace it with a gas fired hot water heater but I didn't want to make a lot of changes at once.
@Steamhead Thanks. I don't know what system the burner came off of but I made sure it had the correct tube and head for the SGO3. I did put a new nozzle on it. I suppose I could have used a single oil line but the old burner had two lines and I didn't want to make a lot of changes at once. You can see the Roth tank in the photos.
The biggest problem I had was learning to sweat solder with the new lead-free solders. I couldn't wipe the solder around the joint to make a nice filet like my Dad taught me. Most of the tools I used were inherited from my Grandfather who was a builder in Summit, N.J.. He didn't have any hand held power tools.1 -
just a pet peeve i usually try to come off the back w the flue instead of the top . also i like to always have a vertical drop on my equalizer and then pipe over to the return horizontally below the water line . its what shown in every installation diagram but its just me and the few peeves i have , i would also throw in a nipple and tee off the skim and install a 3/4 cross tee and pipe the pressuretroll and gauges off that ,they will never get clogged . also remove that front plug and get a full size ball valve to flush the bottom section out usually after a few years there a pia to get out usually have to cut . looks good much better then most i see keep up the good work
peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating4 -
Everybodies got there pet peeves . Your piping job is a vast improvement over the prior and the system must be heating up considerably better then before being now it getting some dry steam stead of wet . Usually after such a up grade in the piping it’s like a whole new system customers are always amazed at the difference in comfort .
Peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating3 -
@CLamb. Make sure you check those packing nuts on your king valves from time to time especially in the beginning.
I had to keep adjusting mine for a while until things settled in. They would go from tight to so loose I could turn them with my fingers.
1 -
The piping reminds me of a vacuum diffusion pump. My guess is that it pumped a lot of water from the boiler into the equalizer but did allow dry steam to go up the mains.EBEBRATT-Ed said:That poor Peerless never had a chance. That F--ked up copper run crooked like that is more work than to do it right
I haven't fired it up yet. The inspectors are coming on Tuesday and after that I have to schedule someone to come and do the combustion tuning.clammy said:Everybodies got there pet peeves . Your piping job is a vast improvement over the prior and the system must be heating up considerably better then before being now it getting some dry steam stead of wet . Usually after such a up grade in the piping it’s like a whole new system customers are always amazed at the difference in comfort .
Peace and good luck clammy0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
