Flow Control Valve
Mikb1957
Member Posts: 12
I'm changing the upstairs zone on my hydronic heating system to radiant floor heat. It used to be baseboard. The B&G F00200 flow control valve needs to be replaced, I was wondering if there is a specific valve I should use with the system. It's a five zone manifold, each with a zone valve.
Is there going to be a mixing valve involved with the radiant, and a separate zone pump?
If so the check in the circ should be adequate.
Or a basic hydronic spring check, serviceable like this.Bob "hot rod" Rohr
Living the hydronic dream1 -
I hope there will be a mixing valve and separate zone pump! Otherwise you are going to overheat that floor...hot_rod said:Is there going to be a mixing valve involved with the radiant, and a separate zone pump?
Or a basic hydronic spring check, serviceable like this.Br. Jamie, osb
Yes, separate zone pump with check valve and a mixing valve. I'll just eliminate the old flow valve. Thanks for the info, very helpful.0
- 129 Chimneys & Flues
- 122 Geothermal
