Mystery odor, baseboard loop
GW
I have a customer, we did a steam boiler change-out 8 years ago, and reconnected her small BB zone for an addition that was done in the 80s.
She is adamant that the BB zone is emanating a foul odor, when the zone comes on. She is certain it's coming from the water inside the piping. I told her odor can't permeate copper tubing. She's not blaming us at all. She spoke to the rodent person and is convinced it's not a dead animal.
Two months ago, we had a language barrier (English is her second language) and we went and ran a system cleaner through the steam system. I think it was 8 way. She says the odor issue got better for 2 weeks.
Any wild thoughts?
Gary
Any wild thoughts?
Gary
Hi, Are there any vents on the baseboard in the living space? Can she describe more fully just what the odor is like? Can you take a sample of the water and have her smell it? Perhaps she has a particularly sensitive nose.
If it's not the water, what's at the baseboard, or what's happening in the space under the bb? Maybe a skunk is living in the crawlspace? Air sealing could help if infiltration is a real problem.
Now for the wild thoughts: Aliens, Bigfoot, Pigpen, and/or Capybara.
Yours, Larry3 -
vacuum and spray with an enzymatic cleaner? Refer them to someone who does that sort of cleaning as a business? Make sure there are no bleeders or valve that are leaking and get rid of any automatic vents(although it shouldn't have those on a hot water loop off of steam anyhow)
Maybe the boiler produces and odor at the boiler when it fires at lower heat for the baseboard? Maybe the ciruclator?
The same water is getting the air on top of it vented at the steam radiators so it should be much worse there if it was the water.0 -
Is there a house pet that frequents that specific area?
Look for the pet doing something there possibly?0 -
Thanks all, I don't know of any animals/pets. I'll send this link to her so she can see some of your comments. My thinking was a dead critter too, but that has been dismissed. Thank you very much0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
