Flooring Installation (Remove Radiators?)
Hello, I am getting LVP flooring put in our house and I was wondering if I should have radiators removed for the installation. Thanks
  • delcrossv
    delcrossv Member Posts: 2,204
    edited February 2024
    If they're freestanding radiators, generally yes. Do you have enough movement in the feed pipes or shim height under the rads to account for the extra floor height?
    TheDavidDDuncan
  • KC_Jones
    KC_Jones Member Posts: 5,939
    When I did the floors in my dining/kitchen area, I disconnected the one radiator in the way so I could lay flooring under it.
    It wasn't too hard even though it's the biggest radiator in my house (12 sections, 38" tall, 60 EDR). I walked it out of the way, laid a few rows of the vinyl flooring, then moved it back and reconnected.
    2014 Weil Mclain EG-40
    TheDavidDDuncanethicalpaul
    EdTheHeaterMan Member Posts: 12,507
    That is why the old timers used unions to connect those radiators. The unions make it easy to disconnect the radiators.
