Which residential, variable speed, ECM pumps, controllable with 0-10 volts, exist in 2024?
I looked on the site and the most recent posts I found were from 2018 or 2019. These are the only two residential class pumps I could find. Are there any others that are variable speed, ECM, controllable with an external 0-10 volts, and are in the same price range as two below?
- Grundfos ALPHA1 26-99 (max flow = 4 GPM, max head = 42 feet)
- Armstrong Compass H20-20 (max flow = 20 GPM, max head = 20 feet)
Thanks,
David
I'm aware that they have different characteristics. This is just a list of the pumps that exist with those features (ecm, 0-10 volts, variable speed, reasonably priced).hot_rod said:What size pump do you need? What is the application?
The Alpha 15-58 takes a 0-10VDC signal
You are comparing 3 widely different type of circulators
A 26-99 is a high head version, same with that Taco.
I don't see the 15-58 as having 0-10 volt external control?
Thanks,
David
1 -
Last line in the Control Mode sectionBob "hot rod" Rohr
Living the hydronic dream0 -
Not sure what you are after -- but you have the cart hitched before the horse. You need to pick a pump which has the head/flow relationship you need first, since all the whizzy control magic in the world can't fix that, and then figure out how to control it.Br. Jamie, osb
Thank you! Somehow those escaped me when I was looking on the Taco site.Dave H_2 said:The Taco 0026e, the 0034e and the 0034eplus all have 0-10v control.
Thanks, but I am only interested in ECM for his list. Having said that, for my own personal needs, I have a 008vdt from about 2011. Is the vv control something that can be added after the fact? If so, would it work on an older unit like the 008vdt? If so, what is the model number of the vv control?Dave H_2 said:
Now these may not be ECM, but any size, standard AC, 00 circ can be ordered with the "VV" control that would accept 0-10
This is just a list of what exists. People can see if the specs match their needs. They might need a steeper curve or a flatter curve.Dave H_2 said:
Whats your application or flow and head needed?
Thanks,
David0 -
I am after putting together a list that people can pick from once they figure out their head and flow needs.Jamie Hall said:Not sure what you are after -- but you have the cart hitched before the horse. You need to pick a pump which has the head/flow relationship you need first, since all the whizzy control magic in the world can't fix that, and then figure out how to control it.
At some risk of sounding like a twit, may I humbly point out that ANY ECM or three phase motor can be controlled with a 0 to 10 volt signal. The smallest such that I know of are found on some personal drones. The largest are multi-ten thousand horsepower motors found on, for example, the SS Queen Mary II. There is nothing magic about an "ECM pump". A pump is a pump, and its characteristics are determined by the internal geometry of the pump. It is powered by a motor. Its characteristics are determined by its windings and armature and magnetic structures. The motor is powered by a power supply -- and that is where the electronically controllled bit comes in.
A more accurate search might be for whether a given maker has an off the shelf pump with analogue (0-10 VDC) control available, or is there an analogue control module available for such and such a pump from an external vendor.
And yes, should you ask, I'm not a fan of "plug 'n' play"" in real world applications.Br. Jamie, osb
The reason I specified ECM instead of PSC, is for reduced power consumption, not related to external control. When I say pump, I mean the pump and motor, as that is how these products are packaged.Jamie Hall said:At some risk of sounding like a twit, may I humbly point out that ANY ECM or three phase motor can be controlled with a 0 to 10 volt signal. The smallest such that I know of are found on some personal drones. The largest are multi-ten thousand horsepower motors found on, for example, the SS Queen Mary II. There is nothing magic about an "ECM pump". A pump is a pump, and its characteristics are determined by the internal geometry of the pump. It is powered by a motor. Its characteristics are determined by its windings and armature and magnetic structures. The motor is powered by a power supply -- and that is where the electronically controllled bit comes in.
I assumed it was understood, when I wrote "controllable with an external 0-10 volts", that I meant it comes with terminals that accept 0-10 volts for speed control. I'm not sure how I could write that any more clearly.
You mentioned "off the shelf". If the question is whether the list should include models that can be modified to be speed controlled via 0-10 volt input, then the answer is -- No, I'm not compiling a list of models that can be disassembled and internally modified to perform differently than the manufacturers intended.
Thanks,
David1 -
@davidd
The VV control is not purchased separate from the pump. However, the pump and controller box looks identical to the VDT like you currently have. Here is the complete range of variable speed 00 circsDave Holdorf
Taco, Inc
1 -
I think you just need to search all the manufacturers offering to see what ECM models have the connection available for 0-10VDC.
Grundfos Alpha and Magna
Taco
B&G aka Xylem
Armstrong
Wilo
Aqua Motion
These are the most common brands of wet rotor style ECM, it is a rapidly changing field, every year you see more options and models available.
It looks like all the brands now offer basic ECM and versions with more features. It is a price game for manufacturers when they start adding features like 0-10 input, etc. Will the market pay more for these features.
I know you mentioned ECM, but a basic "wave chopper" triac relay can be added to the PSC motors to vary their speed. This technology is common on solar controllers to vary pump speed.Bob "hot rod" Rohr
Living the hydronic dream1 -
Thanks Dave. Do you have any document that shows how to wire a 008-vdt for 0-10 volt speed control?Dave H_2 said:@davidd
Thanks,
David0 -
If a pump is purchased with a VV control, does it allow the pump to be used in delta T or delta P mode (or any other modes), or does that control *only* allow for external control?Dave H_2 said:@davidd
Thanks,
David0 -
I think these Grundfos V/S are being phased out, everything is going ECM.
It looks like the control for this and that Taco were built by tekmar OEM division.
I just hook a 9 V battery up to them to get full speed.
I tried searching, but some of the vendors aren't the best about making this type of thing easy to find. I figured it would be valuable to have a list, across vendors, in one spot (here). I know the models change over time. That's why I'm creating this list for 2024. The information I found on The Wall, where this was last discussed, was from 2018 or 2019, so out of date.hot_rod said:I think you just need to search all the manufacturers offering to see what ECM models have the connection available for 0-10VDC.
Taco
B&G aka Xylem
Armstrong
Wilo
Aqua Motion
I'm aware of triacs. I've also seen VFDs (variable frequency drives) being used in AC compressors and submersible well pumps. For the context of this list, it is only about ECM driven pumps that also come equipped to be wired for external speed control. And to be clear, the speed control would be through 0-10 volts DC. Although, I suppose PWM would be an option too. What would not be wanted on the list is any products using proprietary network protocols (like what has happened in the AC market). I don't know if such a thing exists with residential circulator pumps. I won't waste space with that discussion here, other than to say I hope professionals and homeowners alike don't allow that to happen to the hydronic market.
Getting back to the list of pump vendors you supplied, if anyone knows of the exact models that fit the criteria for the list, please post them. I'll periodically update the first post to include the models as people find and report them.
Thanks,
David0 -
Wow!! @dko for the win!! Outstanding!dko said:- Grundfos ALPHA1 26-99
- Grundfos MAGNA3 (ALL)
- Armstrong Compass R (ALL)
- B&G Ecocirc+ 20-18
- B&G Ecocirc XL (ALL)
- Resideo AquaPUMP PCVF-ECM2020 (Armstrong Compass relabel)
- Wilo-Stratos MAXO (ALL)
Interesting note about the Resideo being a relabeled Armstrong Compass. I wonder if there are any feature differences?
Some of these are a bit more expensive, but I'll sift through them and try to put the pumps in low/medium/high buckets.
Thanks!
David0 - Grundfos ALPHA1 26-99
- 129 Chimneys & Flues
- 122 Geothermal
