Gas valve isn't working
Rich Davis_2
Rich Davis_2 Member Posts: 129
Woke up this morning 25 deg outside and the boiler wasn't working. I have a Trangle Tube PS60 it was showing a E 03 I couldn't feel or hear the gas valve clicking, checked the troubleshooters guide and said gas valve cable not properly connected. So I checked the cable and seems OK at both ends. Checked both fuses they seem OK too. So how I determine if it's the cable or the valve. How much voltage should I get on the connections of the cable and should I be able to check the valve with is disconnected? Any suggestions would be greatly appreciated
  • Rich Davis_2
    I checked the resistance on the valve and the readings are with an ohm of that the manual says. I guess my question is how much voltage should I be getting going to the valve?
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,159
    Hi, Is it time for @Jamie Hall 's "quick rap with some small tool" trick?
    Yours, Larry
    EdTheHeaterMan Member Posts: 12,504
    24 VAC is the standard votage for standard valves. inless you have some variable input that operates on DC voltage with the venter motor.
    edited February 2024
    The Trouble sooting Guide for the PS60 that I found indicates that a sensor is open or shorted for a E_31. It does not have a E031 code.
  • Rich Davis_2
    Sorry about the confusion it was a E-03.
