vxt-24 water feeder displaying code
nytech28
nytech28 Member Posts: 116
I came across this boiler which I visually checked, with waterfeeder displaying "26h" see pictures, not sure what code means , it's keeping the boiler off any suggestion would help what the display means .thanks
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,604
    492 gallons of feed water. You are reading it upside down. And the water feeder does not have the ability to turn your boiler on or off
    Jamie Hall Member Posts: 27,403
    I'd have to go find my manual, but I have a recollection somewhere that the VXT will lock out if it senses too much water being fed in too short a time -- and since 492 gallons is about what a residential boiler installed in 1890 might have used by now, if all is well, it may have done that -- and the low water cutout is likely what is keeping your boiler from firing.
    You have a problem, but it's not the VXT feeder. That's just the messenger.
  • STEAM DOCTOR
    Will display "LOC" (I think) if it locks out.
  • nytech28
    it's stock at 492 dispaly
    You're right. I just looked it up...
    109A_5 Member Posts: 4,083
    edited February 2024
    Hello @nytech28,
    26h or 26 HEX is one of the many error messages that you are reading the display upside down. Seriously, if it is 'stuck', maybe it is just glitched. Power it down for a minute or so then see how it behaves. See if it will reset to Zero and work properly.
    https://hydrolevel.com/wp-content/uploads/2021/06/VXT-24-Instructions-web-0321.pdf
  • nytech28
    ok thanks
