Opinion on Pipe Runs in a Kitchen Remodel
nSTP
nSTP Member Posts: 10
Installer laid the pipes yesterday and I'm interested in opinions on the job. It looks really sloppy to me and doesn't look like anything I've seen online. Also, there is a union in one of the pipes which If found interesting.
  • KC_Jones
    KC_Jones Member Posts: 5,939
    Any idea what tubing they used? That doesn't look like any pex I've ever seen. It's brand new, why would they be using a union joint like that? Tubing comes in rolls plenty long enough to not have a joint on a brand new install.
    I agree it looks sloppy, and the spacing is all over the place which could impact performance of the floor creating warmer and cooler areas.
    What's with the expanded metal? Are they doing a gypcrete overpour I assume?
    Did they do a heatloss and design for the room? What's in your estimate with respect to materials and design and such?
    I'd be stopping work at this point, this doesn't look right in any way. Hopefully some of the pros will be along soon for more opinions. Just a fellow homeowner here.
    2014 Weil Mclain EG-40
    hot_rod Member Posts: 27,812
    Certainly not a picture perfect tube installation.
    It looks to be on a tile mesh of some sort, is it going to be a mudset, or gyp pour?
    Gyp is usually poured over a sealer /adhesive, look like Elmers glue
    Concrete is over a slip sheet like 6 mil plastic.
    key to success is a load calc and design assuring you have adequate tube in the space
    I like a 6 or 8” spacing to keep supply temperature low and for fast recovery. Although tight spacing may nit be needed for heat load
  • GroundUp
    GroundUp Member Posts: 2,527
    That's incredibly sloppy, and it also looks like the tubing is too large for this application (though it may be an optical illusion). It appears to be Viega barrier pex so it's acceptable material, but being pex-b it's more susceptible to kinking especially if it's larger than 1/2" diameter which is most likely the reason for the coupling. If this were my home, I'd be stopping them immediately. I obviously don't know what your contract/agreement consists of, so maybe there's nothing you can do, but I would not accept this mess.
  • dko
    dko Member Posts: 669
    edited January 2024
    In a perfect world there wouldn't be couplings, but practically unavoidable. Could have used up a roll and continued on with a new roll. Or had a nick in it so they cut and continued. Wouldn't worry about the coupling.
    It's probably viegapex, but confused by the white stripe on the pex tubing after that coupling. as it should be red stripes only. take a photo of the text on the red stripe pex and the white stripe pex?
    Just have slight suspicion it's not viegapex but pe tubing like https://landscapeproductsinc.com/product/lp710-1-2-inch-red-stripe-drip-tubing-500-foot-roll/
    But the text on the tubing will tell
  • nSTP
    This is part of a much larger remodel project and I don't think I have the details I need on the heated floor. This is what I see ...
    "Install 1/2" heating pex on top of sub floor. Base bid assumes mud/tile to cover pextubing."
    I will take some close up pics of the tubing in a couple minutes and post.
  • nSTP
    Confirmed that it is Viega Oxygen Barrier Pex 1/2 inch. What looked like a white stripe after the union was actually the text shown below ...
    KC_Jonesdko
    The tube is correct, the installation is questionable. I suspect it will heat the space, but if the workmanship bothers you....
    I think Viega wants you to wrap a splice that is embedded in concrete? Tape or a heat shrink cover.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,671
    You don't want that joint in the slab.  No reason on a new install...guys cutting corners.  Very sloppy tubing layout. Is this guy a plumber?  GC? DIY?  Mad Dog 🐕
    ethicalpaul Member Posts: 8,929
    Not DIY, nice try @Mad Dog_2 :sweat_smile:
    Mad Dog_2PC7060
  • Is there a manifold somewhere? What's the longest run of tubing (I see too many older jobs where there is one long run)?
  • dko
    edited January 2024
    Accidents happen like a misplaced fastener or pipe nicked in transit. Wonder how many of you would pull out 200ft(made up number) of already installed and fastened pex, throw it away and start over from the beginning? Wrapped/sleeved pex fittings in concrete is a legitimate repair. Just unfortunate on a new install.
    If OP insisted on a repipe (in the imaginary world it was an otherwise perfect installation) to get rid of the coupling, would it be correct for the contractor to rebill? Honest question.
    Let us know how the discussion goes with the installer, if you do bring it up.
  • Mad Dog_2
    Did the guys name happen to be Paul? Ha ha 😂 🤣 😆 😄 😅 Mad Dog 🐕
  • nSTP
    I am measuring approximately 350' on a single run. Is this a problem as well?
    It comes in 300' coils. Unless someone splices additional length onto a coil. Footage is typically stamped on the tube.
    350 is about as long as you want to go, 300 is the recommended length by the RPA design.
    What you have is workable. 2- 200' loops would have been my choice to get tighter spacing, more consistent floor surface temperature and and less flow restriction.
  • psb75
    psb75 Member Posts: 1,153
    It generally is a shame to skimp on pipe by not dividing the loops appropriately. Aim towards "more pipe". And not necessarily "longer loops." "Similar loops"...is the ideal.
  • nSTP
    Thanks for everybody's help on this. I had the plumbers remove and re-run the pipes. They look a lot better now, maybe not perfect, but a lot better. No more unions anymore either.
  • psb75
    Nicely done on your part. Thanks for follow-up pics. Input from the forum, aided you in negotiations with plumbers for improved results. Now your project has better value and hopefully improved potential for better performance.
    Concrete..."seals the deal."
  • dko
    That's a night and day difference, hard to believe it was the same person??
