Boiler Identification: "a"
jpierce
Member Posts: 2
in Gas Heating
Hello,
I am looking for help identifying the make of this boiler. I've looked through all the various HVAC manufacturer brands starting with an "A" and none seem to use this unhelpfully generic and terribly unsearchable lowercase "a" as a logo. Any pointers would be helpful.
Thanks!
Thanks!
RRRR! Crazy when this happens. Had it happen a few times. When it happens we look to the rafters, the floor joists and behind walls and mounting brackets. Tucked away in insulation?
Have you done the crazy scavenger hunt for that elusive owners manual?0 -
Open the doors and look inside?0
Indeed: https://supplyonline.com/e75cp-rinnai-boiler-max-btu-75-000-combi-lpg.html, thanks!WMno57 said:Rinnai E-series
Apparently the "a" is something that was bolted on by a third party
FYI
The E series appears to be discontinued about 4 years ago. Don't know if parts are still available or not.
https://www.supplyhouse.com/Rinnai-E75CRN-E75C-75000-BTU-Condensing-Wall-Mounted-Boiler-Field-Convertible-NG
https://www.supplyhouse.com/Rinnai-E75CP-E75CP-75000-BTU-Condensing-Wall-Mounted-Boiler-Propane
1 -
Small sticker on the left side, near the bottom, Will give you the serial # 2 letters,six numbers and ends in JB, also on the left side of the white cover should be the model.. definitely an E series0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
