Hot water temp scalding hot
lisap
lisap Member Posts: 10
New boiler recently put in and now my water is scalding hot .  Boiler smells hot at times.  are they connected. Or is there just maybe a problem with water heater.
    pecmsg Member Posts: 7,272
    What’s the mixing valve set for?
    hot_rod Member Posts: 27,812
    Do you have an indirect tank? Tankless coil, combi boiler?
    every type if system should have accurate temperature control. Got a pic we can see?
