Carbon monoxide
zvalve
zvalve Member Posts: 83
Got a free boiler tune up courtesy of national Grid Long Island NY. Only problem according to technician, the CO in flue gases was too high. He made some adjustments of air intake manifold on boiler and CO came down but was not within acceptable level. Does this mean boiler is nearing end of usable life? What causes this and what can be done? Running a hydronic heating system with two zones using Dunkirk PVWB-4D boiler.
  • GGross
    GGross Member Posts: 1,974
    I would call a more seasoned tech out for a tune up, which may cost you some money. The tech was wise to adjust the air, but the unit may require a slightly more complete service, which perhaps the free tune up was not really designed for. When was the last time you had someone clean the burner and heat exchanger?
    ethicalpaul Member Posts: 8,933
    To quote the audience from some game show, maybe Match Game '75, "How high was it?"
  • dko
    dko Member Posts: 669
    "your co is still too high" then says bye and leaves?
    no other recommendations/suggestions? doesn't answer any of your questions?
    is this that 1 tune up rebate per 5 years thing?
    just curious about this courtesy service.
    ethicalpaulGGross
    EBEBRATT-Ed Member Posts: 20,485
    CO in the flu gas. Below 50ppm recommended below 100 allowed. Did he leave a service report?
    Steamhead Member Posts: 18,714
    Most gas burners will have a CO spike when they light off, but then it will drop rapidly. Was this guy just measuring the spike?
    Consulting
