Cyclegard replacement on two boiler system
Athana
Member Posts: 105
Hi..I have two Smith Series 8 Gas fired Boilers to heat this house replacing the one big one that was here before put in 11 years ago.
They came with Cyclegard LWCO.
I think one of the Cyclegards is failing it always seems to be off but goes on sometimes the other Boiler is on all the time no on off.
In this shared water steam one pipe system with two boilers is it possible that I replace the one failing Cyclegard with a Safgard on the one keeping the other Cyclegard as is ? Thanks
- 128 Chimneys & Flues
