Peerless boiler low water sensor
How do yo test a peerless boiler low water sensor
    EdTheHeaterMan Member Posts: 12,448
    edited November 2023
    depends on the LWCO and where it is attached to the boiler.
    The best way is to actually lower the boiler water lever below the sensor and see if the burner will start. But that is not always the easiest thing to do. Some LWCO controls have a test button. Can you tell is what the LWCO model number is and what type boiler is is attached to? and where it is attached to the system?
    A picture of the sensor will help if you can not find the model numbers. Close up and far away to see the whole heater system
