Obsolete Gas Valve
alkaselzr
alkaselzr Member Posts: 3
I have 23 YO Crown boiler with a Honeywell gas valve(VR8305M2177) is not functioning and when it came to replace, the valve is obsolete and no longer available. Both Honeywell and Crown was no help in suggestions of what would be a suitable gas replacement valve. any suggestion on valve to use short of replacing entire boiler?
    Steamhead Member Posts: 18,705
    What model Crown? Can you post a pic?
    Consulting
    EdTheHeaterMan Member Posts: 12,504
    VR8305M3506 may be a suitable replacement.
    I find it hard to believe that Crown's tech support could not help.
    What model Crown Boiler do you have?
    Mad Dog_2
    @EdTheHeaterMan , I suspect this is some sort of direct-spark ignition system. Might be on a conversion burner- Carlin's EZ-Gas Pro uses a similar valve.
    Consulting
    mattmia2 Member Posts: 17,466
    They might have been unwilling to answer depending on how the question was asked since replacing a gas valve with a regulator is not a diy project.
    EdTheHeaterManMad Dog_2
  • alkaselzr
    the Boiler is a Crown CSC-200. according to Velocity(who manufactures Crown) honeywell produced the valves for them specifically for this boiler. and now dont make it. when i call Hoenywell they tell me to call the OEM(Crown) to see if they have a replacement valve. neither firms has an answer for a replacement valve. Hard to believe no one can provide a replacement valve as i would think this is something simple. any other suggestions. like i said boiler is in great shape other than the valve situation.
  • JUGHNE
    JUGHNE Member Posts: 11,603
    Pictures of the gas valve and the entire gas train piping would probably help.
    Jamie Hall Member Posts: 27,581
    Have you tried talking to a professional HVAC person? I can well understand why a company would not be willing to sell a gas valve to someone without training and licensing -- replacing one, never mind adjusting it, is not a do it yourself project.
    Mad Dog_2mattmia2bburd
    R.E. Michel sells a VR8305 that should work. Your service company should be able to get it from them. They do not sell to homeowners.
    Consulting
  • WMno57
    WMno57 Member Posts: 1,408
    WMno57 said:
    That's a 2-stage valve- won't work on this unit.
    Consulting
    WMno57
  • alkaselzr
    absolutely not DIYing i have a HVAC contractor also working on this and having same issue trying to find a replacement valve. When i spoke to Velocity they did suggest a VR8345M4302 however looking at this valve it doesnt appear it will connect from the outlet side(no screw set for gas fitting to screw into the valve. he also noted that "M" is critical meaning it's a series with quick opening valve.
  • tim smith
    tim smith Member Posts: 2,935
    Needs to be done by gas burner mechanic. Have them contact Honeywell contractor tech support. They will help with matching up the specs for the regulator, capacity etc and usually come up with a functional replacement for their valve. Has to be done by qualified tech.
    Good luck
    Mad Dog_2
  • WMno57
    Manual for boiler here. Crown part number for original gas valve is 35-7600.
    http://cdn.spsmsys.com/images/products/pdf/cro01/csc200.pdf
    Good luck
    This.
    Consulting
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,672
    This is a specialty niche...not a hobby or something an average HVAC tech, Plumber or pipefitter can do.  Mad Dog 🐕
