Need help wiring Google Nest thermostat from Honeywell therm.
Hi, I am confused and need help wiring a Google Nest (standard, non-learning) thermostat, replacing a honeywell non-programmable thermostat. If anyone could explain where the wires go into the Nest, it would be most appreciated! I have a pic of the current honeywell wired and will describe which wires are where in case they aren't visible in the pics.
Y2 - empty
W2 - white and brown wires
G - green
W - orange
C - empty
Y - yellow
R - jumper to Rc
Rc - red wire and jumper to R
This is the Google Nest that I'm wanting to connect.
    EdTheHeaterMan Member Posts: 12,506
    edited November 2023
    Appears to be a heat pump that you are connecting that thermostat to.
    Not sure if you should have the C wire connected with the nest you have chosen.
    Need more info on what is connected to the other end of that wire (at the heating unit)
    But I can say for sure that Y=Y, RC=R, G=G, Y=Y and O/B = OB
    The question is weather to place both the black and the white wire from AUX on the W or if you need to get a Pro to figure it out. I would need to see what the other end of the white and black wire is connected to in the air handler
    Ironman
    HVACNUT Member Posts: 7,526
    What are those thermostat wires connected to? Relay, air handler?
    Unless the Nest takes batteries, it's gonna need a C connection.
