Electric furnace blower speed
mike57
mike57 Member Posts: 1
Revolv electric furnace blower speed factory set on high.  Heat distribution uneven. One end is warm the other end gets quite warm. 14x80 mobile home
Wondering if low speed would be be more efficient,less noisy and evenly distribute heat. Thanks
  • ratio
    ratio Member Posts: 4,254
    It's a distribution issue. Changing the blower speed won't have much effect on the distribution. There should be balancing dampers in the various ducts going to the different parts of the trailer. See if you can open the ones feeding the cooler side a little more, rather than close off the ones going to the warmer side.
