Triangle tube cardinal question
CBRob
CBRob Member Posts: 291
For anyone that's installed a cardinal.
There is a factory installed thermowell for the boiler's heat sensor.
The well seems to be installed with sealant and tightened.
Instructions say to seal and torque to spec.
 Before I take it out and reinstall....
Is it already properly sealed and installed.
  • Zman
    Zman Member Posts: 7,614
    I have never seen a residential tank that does not come with a factory installed well. If it looks good, it probably is. Good to see that Triangle Tube is making an alternate to the undrainable tank-in-tank design.
    Albert Einstein
  • CBRob
    I did seal and install the 1/4 turn drain valve 👍
