Steam convector radiators
yes7774
Member Posts: 10
in Gas Heating
I have recessed convector steam radiators in my house. Love the amount of heat that they give off. But recently 2 of them started leaking
once the system was off and the return water was being returned. Does anyone know where I can purchase new ones? They are very hard to find online. Here is a picture of what I have now:
Where exactly are they leaking?All Steamed Up, Inc.
Consulting0 -
They might be repairable. Otherwise, you may need to replace them with a common fin tube radiation or high cap/ high capacity fin tube rad. The one pictured is hard to find.0
Looks like they are leaking from inside, can’t tell if the pipe is cast iron. I do have a video from under it leaking0
Are the common fin tube or high cap fin tube radiators easy to find? Where is the best place to look for them? I may have a plumber install since I don’t have shut off valves on the radiators and I’m guessing they haven’t been removed in a very long time.0
Plumbing supply houses have High capacity also called high-intensity fin tube baseboard.yes7774 said:Are the common fin tube or high cap fin tube radiators easy to find? Where is the best place to look for them? I may have a plumber install since I don’t have shut off valves on the radiators and I’m guessing they haven’t been removed in a very long time.
Doing a heat loss calculation can help for the best amount of radiation needed.
You might need to stack the fin tube in the box .0 -
I had the same issue with a hard to find convector. Check out Governale a company in Brooklyn NY. They manufacture steam radiators and convectors. They make convectors made of copper, steel, or cast iron. Yours are currently steel, so that’s what I recommend. If you email them they will send you a catalog of various sizes and set charts.I got a long steel convector hooked to one pipe steam and it works great. Don’t recommend the copper for steam. If you have a chilly room you can get the cast iron that comes with support stands, this will heat up alittle slower and stay hot longer. If what you have works good then get the steel which is comparable to what you have…0
TwoTones
Thank you very much! I will check them out. Sounds exactly what I need. I have 11 of them in the house so I'm assuming more will go bad eventually.
I called Governale this afternoon and unfortunately they don’t sell to the public. I will have to try a company that they sell to in order to find sizes and pricing. Does anyone know a price tag I’m looking at for them?
I found cast iron radiators that would fit in the recessed areas these convectors are in, can I use 2 cast iron radiators and the other convectors without effecting the system?0
- 119 Geothermal
- 394 Solar
