Quick Thermocouple Question
AO Smith Gas water heater. Millivolts measure constant 28mVDC w pilot lit. Burner runs, when it goes out, the pilot goes out. Took a time lapse. Doesn’t look like TC issue to me. First pic is “normal”. The 2nd pic you can see TC glowing and pilot out.
  • Pipe
    Pipe Member Posts: 16
    Measure MV disconnected from the GV.
    109A_5 Member Posts: 4,158
    Hello @Victor_Wenzel,
    Even though the thermocouple is being heated properly, it does not mean it functions properly. If you DIY it is probably the most inexpensive part you can change.
    Intplm.
    mattmia2 Member Posts: 17,217
    Does it go out because the t-stat is satisfied or is it just going out? flame arrestor water heaters have screens that get clogged and starve the burner of combustion air but that is if it goes out before satisfying the t-stat.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,144
    Hi, Also check, clean and retighten the connection where the thermocouple screws into the gas valve. A tiny bit of corrosion there can mess things up.
    Yours, Larry
    Mad Dog_2Lyle {pheloa} Carter
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,644
    edited October 2023
    Intermittent pilot outages are THE most difficult problems to diagnose & fix. The guys are right. It would behoove you to get @Tim McElwain's opinions here too. He is the King 🤴 in this Particular Kingdom...oh Timmie....Mad Dog 🐕
  • Victor_Wenzel
    Victor_Wenzel Member Posts: 6
    @Pipe, that’s what I did, and it stood solid at 28mV. @109A_5, already on the way. Gets here today. @mattmia2, I took the screens completely off for the test. @Larry, i removed, I did not clean. I will do that when I get home tonite. Thanks a ton you guys! I didn’t know I’d get so many responses so quickly!!
  • I've seen the magnet in the control go bad.
    Larry WeingartenSuperTech
  • Victor_Wenzel
    @Alan (California Radiant) Forbes, is that in the GV? @Larry Weingarten, I tried cleaning the TC wear it screws in. Same result. 😢
  • Victor_Wenzel
    New thermocouple assy…can anyone tell what would cause this?
    What is the gas pressure when it is firing and when it goes out, on both sides of the valve?
  • Victor_Wenzel
    @mattmia2, do I need a special tool for that?
    you need a manometer or a length of tubing fashioned in to a monometer
    Victor_Wenzel
    Does that pilot flame end up in the wrong place after the main burner goes off ? So the thermocouple is no longer being heated. Does the gas tubing or the fitting for the pilot have a leak ?
  • Larry Weingarten
    Hi, It looks like the gas valve is shutting off slowly, or is sticky. You shouldn't have the flame out of the main gas orifice as the last pictures show. There is a chance of carbon buildup in the burner and at the orifice. The orange flame could be a clue. I'd consider washing out the burner and removing/cleaning the orifice. This work needs to be done outside of the heater. Are you on natural gas or propane? Propane can soot up pretty easily if draft is impeded anywhere. Checking gas pressure as @mattmia2 suggested, will help in understanding what's really going on.
    Yours, Larry
    Victor_Wenzel
  • Victor_Wenzel
    Thanks everyone! Turns out the screen under the burner needed to be super cleaned. Blew the hell out of it with compressed air. Started back up and it’s been going ever since. I didn’t know that existed. A buddy told me to try it. Again, you folks rock!!!
