Tankless coil mixer valve
stevel87125
stevel87125 Member Posts: 7
On a new install, with a tankless coil, I see no automatic mixing valve, but a manual gate valve.
With low and high limits set on 160 and 180 respectively, how is a safe DHW temperature regulated?
Thank you
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,679
    A Picture would help to verify...but that's temperature blending from 50 years ago!  You need a Watts or Taco Domestic How water mixing valve....and a thermometer Guage in the mixed outlet is ideal.  Mad Dog 🐕
    Intplm.MikeAmann
  • bburd
    bburd Member Posts: 1,318
    A gate valve? Those must be either fully open or fully closed. Before thermostatic mixing valves became required / standard, a globe valve was normally used as appropriate for throttling service.
    Bburd
    MikeAmannSuperTech
    hot_rod Member Posts: 27,846
    A 520 Caleffi is ideal for  tankless and tankless coil.  Fast responding  and if it loses hot or cold, it shuts down.
    SuperTech
  • stevel87125
    There is no mixing valve. How is the DHW being maintained at a safe temperature?
    pecmsg Member Posts: 7,282
    It's not. The hand valve is old school, run the hot water and manually adjust the hand valve unitl its tempered down.
    Today 120°F is maximum for point of use.
