Leaking pipe
Anon66174
Member Posts: 1
in Gas Heating
My Weil McLain steam boiler developed a leak. How long should it take to fix this? Is it an easy repair?
I would say not in a good spot.. But everything could be repaired. It will take time...
With 2 tees in the mix it is a moderately difficult repair. You have to take apart more than you want to fix it.
Probably take 4 hours and that is just a wild guess.0 -
Some of it could be replace with copper, assuming it is below the water line, which might be easier than disassembling then reassembling the black iron.0
Tough to tell from the close up photo. Is there a floor drain, if so does it work well? Has the boiler been maintained recently, if not the boiler drains are prone to clogging with rust, this adds time. Is the boiler at grade level or are there a dozen squeaky stairs that are missing the third and fifth tread? Does the house have two dogs and two cats that try to sneak out every time we go in and out of the front door? Is there a Blico door to the driveway where I can easily park my service vehicle? Can we come when we want to, or do we have to be there at 6pm when the homeowner gets home from the gym?
I think you get the idea, tough to get all the details from a close up what appears to be older steel pipe that has been painted.1
