Buderus g115 with hydrostat - correct settings?
Hanna61
Member Posts: 34
in Oil Heating
So I finally got the time to reading the materials that came with the boiler due to life craziness, and I just want to make sure I'm reading right.
The boiler is for 3 zones of base board heating only (no domestic hot water), so I gathered that the settings should be:
High - 190
Low - Off
Economy 3 or 4 as one of our zones is set very low though not sure if this matters.
Am I understanding this right?
THanks!
High - 190
Low - Off
THanks!
You may not need it to go as high as 190. You can try lower -- perhaps 180 -- and see if it keeps you warm.Br. Jamie, osb
Thanks Jamie!0
