Controls that people are using.
tim smith
Member Posts: 2,935
Anyone using T775 universal control with pressure transducer instead of vapor stat. Not sure if will work but looks like it might. If so, what transducer have you found to be good choice?
Thanks in advance
Tim
Thanks in advance
Tim
Haven't used the T775 with pressure, but I've used it in its temperature configurations, both for straight control & reset. I like it, simple enough to be easy to set up but powerful enough to be clever with—the last one I installed I used it to control electric heat strips for add-on dehum on a packaged AC unit.
Like I said, no experience with pressure, so I can't say much about a transducer, but ISTR someone posting about an analog control that they built for their steamer. All the transducers I saw that were rated for steam temps were rather expensive, but I might try a cheaper one if the standard controls were left in place.
I think that was on the phidgets platform and pretty cool but don't know if I would trust reliability.0
never liked the T775. Always used the Johnson 350 series which I thought was much better. I think they have a control for pressure but it's just for duct static if I remember right. Don't think they do steam pressure.0
Never had the pleasure.
- 128 Chimneys & Flues
